Discussion topic: multi room box
Message posted on 04 Feb 2024 01:52 PM
multi room box
Hi I have got 3 extra mini boxes and pay multi room but only 1 extra box is working
Message posted on 04 Feb 2024 01:56 PM
Re: multi room box
Did the other two work previously? Which main Sky Q box do you have?
You can have a maximum of 4 mini boxes loaned to you by Sky. You can watch Sky content on two minis and the main box at the same time. You may be able to use a 3rd mini box at the same time if you’re using it for one of the apps such as Netflix.
Be aware the original 1TB (non-UHD) Sky Q box only allows one mini to be in use. To check if you have the non UHD 1TB box check in:-
If it shows as 32Cxxx then you have a non UHD 1TB that only supports 1 active mini box.
All 2TBs and the UHD/HDR 1TB permit two mini boxes. Each mini box which is loaned to you may be subject to a one off upfront charge but you only need one Sky Q monthly Multiscreen subscription.
