Discussion topic: mini will not connect to network
This message was authored by: Glenn67
we had consumer unit in the house trip out several times, since then our 3 mini boxes will not connect to the network, i have reset the main box and all have tick marks, but mini boxes still connecting
Re: mini will not connect to network
Hi @Glenn67
Reboot the minis as above.
If the minis still do not connect try a Network Reset on the minis. Start with the one nearest to the main Q box
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you have the new Sky Max router then you need to connect the WPS to the main Q box.
If you get the first mini connected then for other minis use WPS on the nearest Q device (main Q box or Sky Router (not Sky Max) if on Sky Broadband or previously connected mini).
