This discussion topic has been answered Discussion topic: mini box drops connection regularly
Message posted on 24 Oct 2026 01:15 PM
We have Sky Q with 2 mini boxes. We recently changed Broadband from BT to Sky. The issue is the same and only affects one mini box. The Sky Q box and other mini box work well. The problem mini box was replaced earlier this year. It regularly drops network connection and connection to SKy Q box. I've reset it individually and with the Sky Q box. It is particularly affected by bad weather and if trying to watch a recording but it can also drop connection whilst watching tv. We have a home network which all devices are connected to and work without issue.
Message posted on 30 Oct 2026 06:33 PM
After 36 hours of on/off conversation the signal to our Sky Q box was boosted. At the minute the problem has resolve. Thank you for your help. Only time will tell whether this intermittent problem is finally solved.
Message posted on 25 Oct 2026 10:29 AM
Re: mini box drops connection regularly
Hi @W0lverhampt0n, I’ve escalated your post to our Community Messaging team who will invite you to a private chat shortly and help you with this.
Message posted on 30 Oct 2026 08:21 PM
@W0lverhampt0n wrote:After 36 hours of on/off conversation the signal to our Sky Q box was boosted. At the minute the problem has resolve. Thank you for your help. Only time will tell whether this intermittent problem is finally solved.
How was it boosted?
Message posted on 02 Nov 2026 03:32 PM
Remotely to the Sky Q box
Message posted on 03 Nov 2026 08:30 AM - last edited: 03 Nov 2026 08:31 AM
Yeah but what did they actually do/change? This isn't something I've ever heard of before. And mini box connectivity is a common problem so very curious what resolved it.
Can't see a reason / technical capability where wifi signal strength would be adjustable so I'm assuming they must mean something else. Also not sure there's much on a Q box which can be remotely controlled. Did they change something on the Sky router perhaps?
