Discussion topic: media wall
This message was authored by: seahorsenufc
media wall
hi
how do i get sky remote to control tv if sky q box is hid behind tv on media wall?
Duncan
Re: media wall
hi @seahorsenufc
There will be a few times when your remote must have line of sight of the box - initially & then if things get reset.
Otherwise once paired SKY Q Remotes use bluetooth which do not need line of sight - my SKY Q box is on a shelf behind my TV and works very well (in fact I have used the remote from my rear garden with the box in my front lounge)
We must, however, caution placing a SKY Q box where it might not have sufficient ventilation & the main box in particular should be horizontal not vertical as the Hard disc & other components use the top of the box to release the heat generated
This message was authored by: bob1234
Re: media wall
@seahorsenufcUnless it made of something including metal foil etc it should just work as it is Blutooth.
Re: media wall
Hi @seahorsenufc   All Sky Q Voice remotes work using Bluetooth. Mine works through three walls and a floor.
Avatar for seahorsenufc
Re: media wall
Hi
Id been trying to pair a sky q remote unsuccessfully,hence my post.After the replies Ive received Ive managed to successfully pair my Sky q touch remote (never having ever used one!).does that make sense or should i also be able to pair the ordinary q remote?
seahorse
Re: media wall
@seahorsenufcAs you have a touch controller you may have one of the original set ups where two controllers were supplied BUT one was IR and not Bluetooth so will not work through walls.
Try this link for help with your Q remotes, it will also help identify which controller you have, there were two types of touch controllers one, the later one had a button in the centre of the disc, all touch controllers have been replaced with a button only Bluetooth one.
https://www.sky.com/help/diagnostics/sky-q-remotes/what-would-you-like-help-with.
Re: media wall
@bob1234 wrote:
@seahorsenufcAs you have a touch controller you may have one of the original set ups where two controllers were supplied BUT one was IR and not Bluetooth.
All touch remotes are bluetooth capable - in fact the touch feature requires bluetooth  just like voice control does- I have had all versions
The only 'infrared only' versions are old mini remotes that did not have a voice button (or touch pad of course)
Re: media wall
@seahorsenufc wrote:
Hi
seahorse
You should be able to  pair any non infrared only remote - but note only one remote can be paired with the box itself - only the last one paired remains paired & can be used for voice control
