Discussion topic: main box still freezing
This message was authored by: toptinker
hi this is a updare on the freezing issues i posted last month. plus goint through all this with a sky tech who responded to my problems. having thought after all the info and things to do to solve this i do think its failing again (main box) today i had to unplug reboot reset and did not solve this. had the box freezing channels not responding or a black screen etc so i am really anoyed now with this missing a good half hour of football etc until it finally worked ? i would like to get in touch with whoever it was on the forum  (sky tech) who helped etc. but i presume this will not be possible ? who or how do i demand a replacement box ? i have endured a good 2 months with this issue etc. please advise ?
Re: main box still freezing
Hi @toptinker
Avatar for toptinker
Level 2 icon
thanks. i have done 2 resets tonight. its now working but i have some pixelation etc
Were these just reboots @toptinker @or Reset Settings in the hidden menu?
Level 2 icon
1 was a unplugged etc and 2 full resets
This message was authored by: ThePope27
@toptinker,
Have you tried throwing the box out the window ? I've heard that fixes lots of issues 🤣
________________________________________________________________________________________
Sky Q 2TB v2 Box + 2 Mini Boxes - Brsk BetterNet1000 FTTP, WatchGuard M400 Firewall, Plume Mesh
Sky Signature + Ultimate TV Pack, Sky Sports, Sky Cinema, Sky Kids, TNT Sports, MUTV, LFCTV, Racing TV, Premier Sports, DAZN
Level 2 icon
i would but i have nothin else to view tv. the thought of it freaks me out
