Discussion topic: loosing satellite signal
Message posted on 09 Mar 2024 11:58 AM
My Sky Q satellite signal drops out on a regular basis (almost daily). Reconnects on rebooting the Sky Q box but is becoming a nuisance. Weather is fine and there does not appear to be any issues with the dish. Signal strength when connected is noted as 60 or 70.
Message posted on 09 Mar 2024 12:20 PM
Re: loosing satellite signal
https://www.sky.com/help/articles/sky-tv-no-satellite-signal
Will likely need an engineer to check the alignment/LNB.
Message posted on 09 Mar 2024 12:26 PM
@mjr1
Firstly check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. A dish issue is not necessarily something that will be visible to the naked eye and could only affect one or two channels. If you’re on a communal dish you may initially need to liaise with your landlord or building management company.
