Discussion topic: how to Change sequence of favourites channels with sky Q
This message was authored by: lavillegour
I cannot change the sequence of favourite channels - google instructions do not work.
Any ideas ?  Is it still possible ?
Re: how to Change sequence of favourites channels with sky Q
@lavillegour
Yes you can still add to, remove from, and change the order. See this link
https://www.sky.com/help/articles/using-favourites-on-sky-q
hi @lavillegour
As per the  guide that @Daniel0210  has posted, it is slightly confusing as there are 2 steps
the first is just adding to the list  & you must then Save the list (even if you don't make changes) and proceed to the 2nd step where you can move them before finally saving the changes
Avatar for lavillegour
Level 2 icon
Thanks Guys !
Your are correct. I have been wrestling with this problem for ages.
It is certainly messy. A sort of (not Logical) double move. It seems though that one can only
move a channel to within the required place other than exactly .
Never Mind I am content. .....Thanks again
@lavillegour wrote:
Thanks Guys !
hi @lavillegour
If I am reading your reply correctly, you are having problems setting the order exactly as you want them.
It can be done but is a bit fiddly - moving one channel higher will move the rest down and sometimes there are gaps which do have an option to remove.
It  can take a little  playing around to get the exact sequence you want.
BTW in case you don;t know , unfortunately, favourites are stored on that device and cannot be transferred (e.g. to minis) or backed up & need to be set back up if you have to do a box reset
