Discussion topic: having problems downloading TV series
This message was authored by: Maymay1
I am having trouble downloading TV series is all programs on catch up or demand. I've tried many different programs and none of them are downloading. It says download in progress and it does not download it stays at 0% and doesn't move.
Re: having problems downloading TV series
hi @Maymay1
Try going to
Home - Recordings - Manage - Downloading
And look for an entry that may be stuck -& cancel it - if necessary remove all and try again
Avatar for Maymay1
I have done that I have switched the box of reset it. I have even reset my broadband and reconnected everything and still it is not downloading.
@Maymay1 if there were any that was failed or stuck after deleting them did you also go into the deleted section and delete them from there then reboot you main box
Avatar for Maymay1
Yes, I've tried everything still nothing
