1
This discussion topic has been answered Discussion topic: cooky
This message was authored by: cooky13
cooky
wifi not connect to sky-q after getting fibre fitted today
Re: cooky
Hi @cooky13
With the new Sky Max (white) router you need to connect your Q box by using SSID and password (not WPS).
Highlight Status and then select Reset on the right hand side. Follow instructions to connect by WiFi to your router. Even if reset is not listed there is still an option to connect by WiFi to Sky or 3rd party router.
If you are on Sky Broadband with the new Sky Max router then you need to connect it as if it is a 3rd party router.
If you are on 3rd party (non Sky ) broadband then you need to enter the SSID and password for the router 2.4 Ghz WiFi band.
Any minis on WiFi need togonnect by WPS to the main Q box and not to the router.
Re: cooky
Hi @cooky13
