5
This discussion topic has been answered Discussion topic: Sky Q box won't connect to modem (sky modem)
This message was authored by: Dee00
I lost my connection for no reason as worked fine until yesterday.  When manually adding password it says wrong password when I 💯 know its correct as we never changed password.   Tried everything but no connection.  Do I need an engineer sent out
Re: Sky Q box won't connect to modem (sky modem)
Hi @Dee00
On Sky broadband hold the Reset on the back of the router until the power light flashes green (about 10 seconds). Don't unplug or switch off your router while it resets. The power light will go green when it's done.
Highlight Status and then select Reset on the right hand side. Follow instructions to connect by WiFi to your router. Even if reset is not listed there is still an option to connect by WiFi to Sky or 3rd party router.
On Sky Broadband you will be asked to press the WPS button on the Sky router. (Not on the Q box as the Network reset will start the main Q box WPS automatically). Make sure you press the WPS button on the Sky router and not the reset button.
If you are on Sky Broadband with the new Sky Max (white) router then you need to connect it as if it is a 3rd party router.
If you are on 3rd party (non Sky ) broadband then you need to enter the SSID and password for the router 2.4 Ghz WiFi band.
Hi @Dee00
Avatar for Dee00
I've reset sky modem and nothing ..I've powered off sky box for while and nothing the Internet works on ALL other devices except my Sky  Q box . Thanks for reply
Have you tried the Network reset as per my post @Dee00 ?
If on Sky Fibre with the new Max (white) router then you connect using SSID and password.
If you have the black Sky router then you need to use WPS (all as per my previous post)
Avatar for Dee00
I think my WPS button is broken as dosent seem to be pushing in? Odd as was all OK yesterday.
Hi @Dee00
Are you pressing the correct button?
