Discussion topic: Youtube keeps freezing
This message was authored by: welshguy2017
Hi all, anyone else having problems with Youtube? I have reset the App, updated Sky Q to the latest software, but still is laggy, especially when i pause something then restart.  Any idea?  Thanks
Re: Youtube keeps freezing
See this thread: https://helpforum.sky.com/t5/Sky-Q/YouTube-on-Sky-Q-quot-loading-quot-after-pausing/td-p/4456371
In a nutshell, following extensive testing Sky do not believe this is a Q issue and advise users to reach out to Google/YouTube to try and get them to make further updates to the app for a permanent fix.
Or use another device if feasible.
