Discussion topic: Youtube Freezing/Crashing
This message was authored by: yatesstace
Hi all was wondering if there was anything I could do regarding my YouTube app.
Seems to 'buffer' then jump back about 15 seconds on a video not Everytime but enough for me to be bothered by it
Then other times it closes completely? Is there anything I can do. Apologies if this has been discussed before
Stacy
Re: Youtube Freezing/Crashing
@yatesstace
Yep, known issue that is waiting on a fix which has been raised multiple times, this is probably the best thread to follow: https://helpforum.sky.com/t5/Sky-Q/YouTube-on-Sky-Q-quot-loading-quot-after-pausing/m-p/4456371
Sadly the best recommendation currently is to use another device to watch YouTube until it is fixed properly.
