Discussion topic: Sky q box is showing accessibility on sky q and can’t get it working
Message posted on 27 Aug 2024 09:55 PM
Sky q box is saying accessibility on sky q and won't move from settings
Message posted on 27 Aug 2024 10:02 PM - last edited: 27 Aug 2024 10:04 PM
Re: Sky q box is showing accessibility on sky q and can’t get it working
Hi @Janetwills
First reset your remote to infrared
In infrared mode it will work the Q box but needs direct line or sight.
Once you get the box working you can re pair the remote
With the Qbox on with green led make sure that you are pointing your remote at the Q box and press 1 & 3 together until the remote led flashes and follow onscreen instructions to re- pair.
