3
This discussion topic has been answered Discussion topic: Your services may have an issue
This message was authored by: Lauren260
My Sky App  keeps telling me  they've detected an issue with my Sky Q box but when I go to 'fix issue' it asks me what the issue is. Well, I don't know because it seems to be working fine to me. How can I find out what issue is being detected? All help appreciated. Thanks
This message was authored by: Laing1 Answer
Re: Your services may have an issue
@Lauren260 @phrobr b
eing honest unless you can see you have a problem with your box/boxes then if the app tells you there is a problem i'd ignore it a few have had the same as you and it seems it's a glitch in the app
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
This message was authored by: phrobr
I have exactly the same situation which has been going on for several weeks.  I am now simply ignoring it. Good luck!!!!
This message was authored by: Andym15
It's very unreliable imho.
I do have a problem. I suspect the LNB has cooked in the heat waves and I have no satellite signal.
MySky is currently telling me everything's OK. Fortunately it did detect a problem for long enough for me to be able to book an engineer online saving me having to call them.
As @Laing1 said, if you can't see a problem, ignore it.
Answered - Go to Answer
