Discussion topic: YouTube won’t load
This message was authored by Claire601 This message was authored by: Claire601
YouTube won’t load
YouTube won't load through the sky box but will load through internet
This message was authored by lettice This message was authored by: lettice
Re: YouTube won’t load
Try refreshing your apps;
  1. Press Home on your Sky Q remote, then highlight Settings
  2. Press 0,0,1 and Select to access the Installer menu
  3. Select Apps then highlight Refresh all Apps on this box. You'll see a message that says, 'Your apps are being refreshed'.
  4. Press Dismiss to return to normal viewing.
The refresh can take 24 hours to complete.
Sky Community Superuser. What is a Superuser? Click here to find out
Sky Stream (2 pucks), Sky Ultrafast + using Sky SR203 hub. Sky Protect kit tester.
This message was authored by Quoman7 This message was authored by: Quoman7
Hi @Claire601 Try rebooting your router by removing the power cable for 30 sec then reconnect to reboot, then reboot your main SKYQ box by turning the power off at the socket for 30 sec then turn back on?
This message was authored by Kerrie1978 This message was authored by: Kerrie1978
It's every day with sky. They change you sky high prices and it's constant problems. I'm sure we can get better from a different provider with all the same stuff for less cost. I'm sick of sky. I've o ly had it a few months and already my bill has gone from £70 a month to over £100. And every day there has been a problem. This has hot tk change. They are robbing us blind a d the last time sky went down I was told it was because they got hacked and they stole all our personal data.
Mine won't load either. It's a new problem every day with sky. Last time it went down it was because they got hacked and had our personal data stolen. So much for protecting our personal data.
Do you have a fix for the puk please
This message was authored by Laing1 This message was authored by: Laing1
@Kerrie1978 can you expand on your comment Last time it went down it was because they got hacked and had our personal data stolen . Last time what went down ? if you mean YouTube then if YouTube was hacked that has nothing to do with Sky
