Discussion topic: Would like sky moved into another room
This message was authored by: PENFOLDONE
Need an engineer to move my sky equipment into another room need new cables
Re: Would like sky moved into another room
@PENFOLDONE Afraid you are not contacting Sky's customer services on here, this is a customer to customer forum where customers help each other.
Could you get away with adding extension cable to your current cables to allow you to move the boxes yourself. If not then you will need to contact Sky but they may or may not charge £65.00 to move the cables for you,
The third option is to look at an independant installer who would be able to re-run the cables for you
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
