Discussion topic: WiFi keeps dropping
This message was authored by: Samit
WiFi keeps dropping
Hello.
On my Sky Q WiFI internet keeps dropping. Router is not far away at all.
Not sure what's the remedy for this?
Thanks.
Re: WiFi keeps dropping
@Samit wrote:
Hello.
Thanks.
Hi @Samit
Do you have the new Sky Max white router?
Avatar for Samit
Nope. I'm using EE router.
Any chance you can connect your Q box by Ethernet to the router @Samit ?
Avatar for Samit
Not really as the router is on the next room.
Ethernet has been installed between multiple rooms for decades. But if you don't want to do any DIY, powerline adapters might be easier.
also ethernet on these EE routers seems to be problematic anyway.
Avatar for Samit
Thanks for reply. I can certainly try that.
Presuming with this solution Sky Q box got WiFI connection problem? Not sure whether anyone else has had the same problem?
Plenty have
