Discussion topic: Wi fi connection issue
This message was authored by: HelenJJ1
Hi my sky box only occasionally is connected to wi fi when I turn it on.  I have, spoken with a sky staff member and done all the turning  off of box and wi fi etc, and it does connect eventually, but all that takes time.  It does connect if I type password in to wi fi connection, that takes time also.  I dont want to be doing this every time I turn box on.  Help please
Re: Wi fi connection issue
Hi @HelenJJ1
Have you tried completly resetting you Q box connection?
