Discussion topic: Where's WPS button?
This message was authored by CastleDoor This message was authored by: CastleDoor
Where's WPS button?
I rebooted my Q Box. Onscreen message tells me to press and hold down WPS button on modem. Sadly my modem has no WPS button. System times out, so what to do next? Fed up.
This message was authored by Chodley This message was authored by: Chodley
Re: Where's WPS button?
On your wifi router, not modem (though some are a single box). It will almost certainly have a WPS button. If it's not an old school Sky router, wps won't work though.
This message was authored by Mark39 This message was authored by: Mark39
Are you sure? Unless it's very old there should be one. Check the sides of the router, as well as the back and front panels.
CastleDoor
I am disabled and can't get to it myself. As soon as my wife gets back I will ask her to check it over. The only button so far found is a tiny red recessed  button, which reboots the moderm.
If it's a Sky one, it's on the edge/side
CastleDoor
Is 12 or 15 years considered as old? Because that is how long we have had it. It was provided by Sky.
Yes. Very.
CastleDoor
Will Sky replace it or what?
The models still in support are:
2013 Sky Hub
2016 Q Hub
2019 Sky Broadband Hub
2023 Max Hub
All of those have WPS buttons somewhere.
Well if they do you might end up with a Max router that works even worse with Q
CastleDoor
So best to replace it myself? If so what is recomended (presumably with a WPS button?)? Thanks.
They will all have the same problem as the sky max router. Lack of integrated Q mesh networking.
I'm sure your current one must have a wps button.
This message was authored by fluffytag This message was authored by: fluffytag
It is on the right hand side of router, on the edge of router.
This message was authored by Nick241248 This message was authored by: Nick241248
It's on the right hand side of the router, near the bottom. You can't miss it
This message was authored by Laing1 This message was authored by: Laing1
@CastleDoor if your router is 12 to 15 years old is is more than likely thy Sky hub sr102 does it look like the picture below if it is then the wps button is in the middle of the router on the front with 2 lights abobe it and 2 light below it
