cancel
Showing results for
Search instead for
Did you mean:
When trying to access UHD : there is a technical issue code UHD 1 ?
Garyjn
Level 1
Cannot access ultra HD just keep getting the above message saying please try later. And it says 1.18.0 at the bottom of the screen
5 REPLIES 5
PandJ2020
Level 16
Re: When trying to access UHD : there is a technical issue code UHD 1 ?
That sounds like a message from your TV?
was it working and stopped?
Garyjn
Level 1
 Essage comes up when pressing red button trying to access uhd on channel 404
oldfella
Level 16
Hi @Garyjn
See if you get the same error trying to access the UHD content in
Home - Sport - The Ashes
Mike102
Level 0
I keep getting same message says Technical issue and code UHD1.
cannot see a solution on the chat . Next steps?
Chodley
Level 14
what TV are you using?
