Discussion topic: When the screen goes blank press home to get started problem
This message was authored by: MrQNumber10
Sky box has failed with a couple of recordings recently and last two days been stuck on same channel despite trying to change channels or play recordings..  turned off and left and turned back on, followed online guides on here but now just cycling through the three steps ending with the blue screen and message to push home when screen goes blank.  Has done it about 5 times now and still can't get it back on.  Having read a few posts on here seems to be a fairly common issue and means the box has failed?  Can someone advise please?
thanks
Re: When the screen goes blank press home to get started problem
thanks
Hi @MrQNumber10
If you have worked through the folliwing link and cannot solve your issue it does lead to a conclusion.
https://www.sky.com/help/articles/sky-q-box-wont-turn-on-v2#:~:text=Restart%20your%20Sky%20Q%20box,b...
Avatar for MrQNumber10
yes tried that already from a different post about same issue and no joy.
thanks though
This message was authored by: philavi
Best to just leave sky. Have reported this issue to sky for months and they don't care about it.
