Discussion topic: When i press home button my screen shrinks
Message posted on 13 Mar 2025 07:25 PM
i cannot get my sky. When i hit home button my screen shrinks and moves to top left
Message posted on 13 Mar 2025 07:42 PM
Re: When i press home button my screen shrinks
Hi @Jules77- Have you tried a power reboot? Switch your Sky Q box at the mains plug, wait 30 seconds and then switch it back on.
Message posted on 14 Mar 2025 08:43 AM
Also check that the HDMI leads are fully plugged in on both ends. Loose connections can cause odd visual effects.
Pete.
Message posted on 21 Mar 2025 04:35 PM
I've just had the same thing. It started with a lost connection to the router but other devices were still fine. Most remote buttons stopped working. The Home button shrink the screen top-left and only the Exit button brought it back. Couldn't access any other pages though so it was stuck on the last channel viewed. Did a hard reset (unplug) as advised here and it seems to have worked. First time this has happened.
