Discussion topic: We have a problem with 2 Sky Q boxes which say they cannot connect to the internet
This message was authored by: Janethackray
We are having a problem with the 2 sky Q boxes attached to the main box, saying we are not connected to the internet
Re: We have a problem with 2 Sky Q boxes which say they cannot connect to the internet
Hi @Janethackray
Reboot the minis as above.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you get the first mini connected then for other minis use WPS on the nearest Q device (main Q box or Sky Router if on Sky Broadband or previously connected mini).
