Discussion topic: My skybox won’t play a recording without freezing
Message posted on 25 Oct 2023 08:47 PM
My skyQ box won't play a recording without freezing then saying there's a problem with the network you can press forward and it starts again for a few moments then starts again. A few seconds later same issue
we also have an issue when forward and rewinding it seems to get stuck
Message posted on 25 Oct 2023 09:01 PM
Re: My skybox won’t play a recording without freezing
Hi @John0066
Message posted on 02 Dec 2023 12:27 PM
Skybox won't record programmes or show recorded programmes as it states issue with hard drive ?
Message posted on 02 Dec 2023 12:30 PM
Skybox won't record or show recorded programmes ?
Message posted on 02 Dec 2023 02:06 PM
@Davindersodhi have a read of the link below
https://www.sky.com/help/articles/sky-q-hard-disk-error-messages
Message posted on 30 Apr 2024 11:27 AM
Having this issue on our Sky Q box irrespective of it's live tv, downloads or recordings. Did both 'soft' and 'hard' resets to no avail. Personally I think it relates to disk read/write errors internally. My thoughts are it's the 'beginning of the end' for your unit - just order a replacement.
