Discussion topic: We are not able to get BBC1 OR BBC2
This message was authored by: Lesleys1
Message on screen
"This channel is currently affected by a problem with your satellite signal."
Re: We are not able to get BBC1 OR BBC2
@Lesleys1
If a “no satellite signal” message is displayed, that relates to your Sky Q box, so firstly check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Also check out the troubleshooting on this link
It may then give you the opportunity to arrange an engineer to check the alignment of your dish.
A misalignment is not necessarily something that will be visible to the naked eye and could only affect one or two channels. If you’re on a communal dish you’ll need to liaise with your landlord or building management company who deal directly with their approved engineers.
