Discussion topic: Says techincal fault on screen how do i fix it
This message was authored by: Steveo5
Screen says technical fault, how do I fix it, been same all day
Re: Says techincal fault on screen how do i fix it
@Steveo5
First thing to try is a reboot of the main Sky Q box, then once that’s back up and running do the same with any mini boxes if necessary-
~ press the 🏠 button
Avatar for Steveo5
Level 0 icon
All sorted thank you, a reboot did the trick
This message was authored by: Tracey93
It did not work
@Tracey93
If the reboot didn't work try the troubleshooting on this link.
https://www.sky.com/help/articles/there-is-a-technical-fault-with-this-channel
