Discussion topic: Volume setting
This message was authored by: Deen1976
Volume setting
I can't get volume set on sky remote
Re: Volume setting
Hi @Deen1976
Volume setting of Q remote can only be done if the remote control is correctly paired to the Television set.
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the remote led flashes and follow onscreen instructions to pair to the television
