3
This discussion topic has been answered Discussion topic: Volume control
This message was authored by: Dibb
Volume control
Hi there
just got a new sky q remote but it would seem the volume not working- the virtual assistant said press 7&9 hold for 4 flashes but it still not working- we can hear ok but can't silence or turn up/ down
sorry just to add voice control not working either
Re: Volume control
@Dibb wrote:
Hi there
Hi @Dibb
You need to do all the following to correctly pair your remote.
Re: Volume control
@Dibb wrote:
Hi there
Hi @Dibb
Re: Volume control
@Dibb wrote:
Hi there
@Dibb Try resetting your remote.
Press the buttons 7 & 9 together on the remote until it’s led flashes four times.
Then press 1 & 3 together until the led flashes twice then follow onscreen instructions to repair the remote.
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Avatar for Dibb
Level 2 icon
Re: Volume control
Many thanks Laing1 all sorted now
merry Christmas & once again thank you
