Discussion topic: Volume buttons no longer work
Message posted on 24 Mar 2025 09:59 PM
The volume buttons have suddenly stopped working on my Sky Q voice remote. I even ordered a new remote as I thought the old one was broken but they still don't work? I've pressed 1 & 3 to pair, but it doesn't recognise my Samsung TV to finish set up? I don't understand why? Is it because my TV is now too old? Not sure what I'm supposed to do? I need to be able to control the volume?
Message posted on 25 Mar 2025 07:44 AM
Re: Volume buttons no longer work
Well you could just use the TV remote
but if it once worked it won't have stopped working. most manufacturers' TVs share IR codes so select the closest model in the list.
Message posted on 25 Mar 2025 03:57 PM
Yes, but I don't want to use two remotes. It did work then suddenly stopped working for some bizarre reason. There are hundreds of Samsung TV's on the list and I haven't got time to go through them in the hope that one of them works.................. Looks like i'll have to use two remotes! Thanks anyway 🙂
Message posted on 25 Mar 2025 07:26 PM
Like I said, pick the closest model number. No one sane would try all of them 🙂
Message posted on 28 Apr 2026 11:29 AM
Remote is broken apart
Message posted on 28 Apr 2026 05:32 PM
@Kimberley01 try using the link below to order a new remote
https://www.sky.com/help/articles/lost-stolen-damaged-sky-q-equipment#get-in-touch
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
