Discussion topic: Vokume keeps dropping out every 5 seconds
This message was authored by: AB94
Volume keeps dropping in and out every 5 seconds .
i have read on other forums that other people have experienced the same problem but Sky state that there is no problem other than its peoples TV  ( Samsung ) and not thier equipment .
Having just been told that i am the  only person to have experienced this issue i am frankly finding hard to believe .
This message was authored by: AndrueCope
Re: Vokume keeps dropping out every 5 seconds
What channel(s)? There has been a problem ongoing for over a year now with Discovery HD. Sky/Discovery either won't or can't fix it - last I heard on here was that despite numerous people posting dates/times they couldn't reproduce the fault.
The only known workaround is to disable Dolby Digital audio output. It's not a complete fix but it does reduces the frequency and duration of the dropouts to a tolerable level.
Avatar for AB94
Hi
thanks for the  response , its on all channels and yes i did try disabling the Dolby but it has not cured it .
I also tried the reset which someone else had suggested on another thread .
