5
This discussion topic has been answered Discussion topic: Voice command not working
This message was authored by: MattMaines
Remote voice command is not working. How do I fix this?
This message was authored by: Laing1 Answer
Re: Voice command not working
@MattMaines try rebooting your router then the Sky Q box
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
@MattMaines
As there is no voice command option on Sky Go  (where you have posted) on what platform is this, Sky Q, Glass or Stream ?
Avatar for MattMaines
Hi, it's Sky Q that I have
Thanks @MattMaines , I have moved this to the Sky Q forum for you.
Just did this and now working.
Thanks 👍
