Discussion topic: Box update
This message was authored by: Amyc628
Box update
My sky Q box does its daily update about 6am every day.
Its been like this for as long as I can remember.
With my new job I'm now up earlier and like to watch tv while I have a cuppa. Unfortunately this isn't possible as, due to the update, I can't watch tv till after 6am.
Its like this every single day.
How can I change the time of the update so it happens in the early hours?
Re: Box update
Hi @Amyc628   You need to check your Standby Settings You should note that it is not an update, it is just a reboot.
Re: Box update
It's not an update, the box is just waking up from Eco Mode. It goes into Eco Mode from 02:45-05:45 to save power. You can't change the time but you can disable it, see https://www.sky.com/help/articles/using-the-standby-settings
Active Mode would be best so the box still goes into normal standby when not used but will not go into Eco mode overnight.
Avatar for Amyc628
Re: Box update
Oh amazing,  thanks. I'll try that.
