Discussion topic: Virgin Media Broadband and SKY TV Box best configuration
This message was authored by Spindizzy2012 This message was authored by: Spindizzy2012
I am currently thinking of ditching Virgin Media, however it's broadband is far superior to that which SKY could offer me.
SKY TV services is my goal, attached to the VM broadband. Has anyone got any advice on the possible configuration and operation of such an arrangment?
Many thanks
This message was authored by bob1234 This message was authored by: bob1234
Re: Virgin Media Broadband and SKY TV Box best configuration
@Spindizzy2012It should be no trouble just use WiFi to connect your Main Q box to the Virgin WiFi.
Here is information on how to set up Q devices
https://www.sky.com/help/diagnostics/setting-up-sky-q/what-sky-equipment-do-you-have
Spindizzy2012
Thanks @bob1234  much appreciated
This message was authored by ozsat This message was authored by: ozsat
I have my main SkyQ connected to the VM service my Ethernet. The SkyQ main and mini boxes use their own network to communicate.
No issues.
Many thanks
SkyQ Silver bundle (V2 2TB with UHD/HDR + two minis) in Sky region #71 (Oxford) using VirginMedia Gig1 Fibre (1.2Gbps/100Mbps).
This message was authored by xenon81 This message was authored by: xenon81
Same here. Sky Q box connected via ethernet to my own router on Virgin Media and no problems
Spindizzy2012
Thanks @ozsat much appreciated.
Spindizzy2012
Thanks @xenon81 much appreciated
This message was authored by StevenW007 This message was authored by: StevenW007
Interesting that I have the exact same setup as other posters with sky q hub connected to Virgin hub via Ethernet and then mini boxes via wifi mesh.
im constantly having no internet on any box when I first turn it on. With the main box internet kicks in after a few seconds and all is fine. With the minis I have to go downstairs to turn the main box on (and as above that comes on with no internet before it kicks in) and the minis will no function.
it's a real fad having to do that all the time.
any tips from anyone?
Spindizzy2012
Thanks for explaining your setup. I am not aiming to have virgin broadband and SkyQ until later in the yearso can't comment on your issue from a hands on point of view.
As this is an old post now, I would suggest you start another thread to get resposes.
Good luck
This message was authored by Denster This message was authored by: Denster
Hi spindizzyi have virgin broad broadband also I have sky q box,and it works perfectly well, I hope this helps.
Denster do you have any minis in your setup?
since i posted almost 2 years ago and have tried a number of configurations with different internet providers but always encountered intermittent issues as the sky q mesh system clearly conflicts with other mesh/wireless networks.
The most stable (faultless) configuration is what I now have which is all boxes connected via Ethernet and sky q mesh disabled.  Pain to set up in the first place running Ethernet cables to all locations but well worth it
