Discussion topic: Viewing card
Message posted on 06 Jan 2024 11:38 AM
Viewing card
Hi
Ive got a massage saying please ensure the correct card is inserted with the chip facing up this morning, but ive not recived a new card. My internet went down this morning as well, so is the message o because i have no internet
Message posted on 06 Jan 2024 11:46 AM
Re: Viewing card
No, a viewing card issue is unrelated.
Try cleaning the card with a soft cloth, reinsert and reboot the box if required. If that fails, you'll have to contact Sky for a replacement card.
Message posted on 06 Jan 2024 12:42 PM
Re: Viewing card
@Stujc wrote:
Hi
@Stujc if after btrying @PandJ2020 suggestion when your internet is back up and running You could try refreshing your viewing card by pressing home > settings > system info > viewing card number > setup > viewing card setup press select to trigger a callback don't worry nothing to do with your phone its only Sky's terminology this will be done over the internet
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
