Discussion topic: Viewing card
This message was authored by: Becky08
Viewing card
I've got an error message stating 'please ensure the correct viewing card is inserted with the chip facing up.' I've followed the troubleshoot guidance online by removing the card and putting it in again and unplugging my sky box and restarting it but still have the same issues. Does anyone have any advice?
Re: Viewing card
Hi @Becky08
First check that your viewing card is correctly inserted. Viewing card is in the right hand end of the box.
If it is in correctly there is not enough of it sticking out to grip and remove it.
Push it fully in and it will pop out slightly enough so you can remove it.
Make sure that it is in chip side up and chip end in first. Push it gently fully in and you should feel a slight click when it is engaged. If it has popped out enough to remove it is not located correctly.
If you are satisfied that it is in correctly
Try refreshing your Viewing card.
Home - Settings - System info.
Highlight Viewing card number and then select Setup on the right hand side.
Then select Use this option to trigger a callback
No call is actually made but the Viewing card should be refreshed.
Avatar for Becky08
Re: Viewing card
Hi! Thank you for your help 🙂
The viewing card is definitely inserted correctly as I heard it click when I put it back in and I've tried several times.
I've tried refreshing the viewing card but in the 'viewing card number' section it states 'no csrd inserted' so I've gone across to 'setup' and it just states 'please ensure the correctly viewing card is inserted with the chip facing up.' There's no option to trigger a call back?
Becky 🙂
Re: Viewing card
Becky 🙂
Hi @Becky08
There will be no options if the Viewing card is not registering.
Try rebooting your Q box  and try the viewing card removal and reinsertion again.
Avatar for Becky08
Re: Viewing card
Hi
Thanks for this. Yes I've followed that procedure several times today and it hasn't rectified the issue so I've just spoken to Sky on the phone and they've offered me a replacement viewing card. Fingers crossed that fixes the issue 🙂
This message was authored by: LesleyA
Re: Viewing card
I am having exactly the same problem and the voicemail message said go to the forum.   Have tried everything that was on the message trail and still nothing... any advice?
Avatar for Becky08
Re: Viewing card
I had to have a new viewing card sent out to me!
