Discussion topic: Viewing card
This message was authored by: Jamie+Davis3733
Viewing card
My tv is saying insert viewing card with chip facing up. I have sky q and don't have a viewing card
Re: Viewing card
@Jamie+Davis3733 Sky Q will only work on free to air channels without a viewing card in the box simple as that. If you try to go to an encrypted channel which includes a number you dont have to pay for you will get that message. What channel were you trying to tune to?
Re: Viewing card
Hi @Jamie+Davis3733 If you have just recieved a replacement SKYQ main box, you would have needed to take your viewing card out of you previous box before it was returned.
You will need to call SKY and ask for them to send you a new viewing card before you can watch any none
freeview channels as descibed in the pos by @Chrisee
Avatar for Jamie+Davis3733
Re: Viewing card
I've had sky q for a few yrs and this message started a few days ago. I've not changed anything. Will phone sky as there must be some technical issue, but thanks for your reply.
Re: Viewing card
@Jamie+Davis3733 then your viewning card should be inserted in your SKYQ box on the right hand side, it may have popped out, so try and push it gently back in until it clicks?
Re: Viewing card
@Jamie+Davis3733 just to be certain viewing cards on Sky Q can be found in the slot that is on the right hand side of the Q box towards the front only a few millimeters of the card stick out so it is easy to miss
To remove the card you need to push it in and it will release it then give the chip a clean with a soft dry cloth
Put is back in and push it until you hear it clicking into place
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
This message was authored by: Carol79
Re: Viewing card
On every station it keeps saying insert viewing card this has been since Christmas day rather annoyed is an understatement.  I pay insurance and repair for tv I would like an engineer out today or I'm moving my broadband
Re: Viewing card
Have you removed the viewing card, gently wiped in with a lint cloth and then reinserted it?
If you have cover through Sky Protect with Domestic and General Insurance you can try to contact them but the chances of them, or Sky, having engineer availability on Boxing Day are unrealistic.
As we are customers here like yourself making threats to move services is irrelevant.
Re: Viewing card
If this is Sky Protect then the terms you agreed are next day at best.
