Discussion topic: Viewing card not working
This message was authored by: Loub123
Re: Viewing card not working
Try taking it out, cleaning it with a soft cloth and reinsert it.
if that doesn't work you will need to contact Sky for a replacement.
@Loub123 if @PandJ2020 suggestion doesnt work You could try refreshing your viewing card by pressing home > settings > system info > viewing card number > setup > viewing card setup press select to trigger a callback don't worry nothing to do with your phone its only Sky's terminology this will be done over the internet
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
