Discussion topic: Viewing card not paired
This message was authored by: Leehano
Hi, I have just moved house and had an engineer out to sort sky, but we can't access it, it's saying "viewing card not paired" we do r have access to internet until Friday but surely must be able to get more channels than only your basic ones
Re: Viewing card not paired
Hi @Leehano
First check that your viewing card is correctly inserted. Viewing card is in the right hand end of the box.
If it is in correctly there is not enough of it sticking out to grip and remove it.
Push it fully in and it will pop out slightly enough so you can remove it.
Make sure that it is in chip side up and chip end in first. Push it gently fully in and you should feel a slight click when it is engaged. If it has popped out enough to remove it is not located correctly.
If you are satisfied that it is in correctly
Try refreshing your Viewing card.
Home - Settings - System info.
Highlight Viewing card number and then select Setup on the right hand side.
Then select Use this option to trigger a callback
No call is actually made but the Viewing card should be refreshed.
Avatar for Leehano
Thank you, I've done all of these but when it says it requires a internet connection to do the call back. So at a loss really until we have internet on Friday.
Yes OK @Leehano
The fact that you Do Not have internet is not clear from your first post.
Avatar for Leehano
It was a Typo sorry! What I'm trying to say is we can only access 3 channels but surely must be able to access more without internet!
Not until your viewing card is paired @Leehano
Avatar for Leehano
That's what I'm trying to figure out! How to pair it.
As far as I am aware You will not be able to without internet @Leehano
@Leehano do you have a mobile phone that you can set a hotspot on ypu mobile phone so you can link other devices to your mobile internet data.
If you can turn the hotspot on and see if you can link your Q box to it then follow @oldfella advice
Avatar for Leehano
Yeah we have already tried that, for some reason it will only let us hotspot to the Xbox and not the tv or sky. It's ok we will have to make do until Friday 😅
