Discussion topic: Viewing card not inserting properly
This message was authored by: Gary_S18
The viewing card will not insert and click in place. It keeps 'popping' back out so that maybe 3 or 4 mm is still visible.
The sky Home Screen says card not inserted. Have cleaned and reinserted, and also rebooted the system but no luck.
is this a card or sky box issue?
Re: Viewing card not inserting properly
Are you fully inserting the card? There is a quite deep spring that you need to overcome for it to click into place. It will go much further in then you might expect. If it's not that then it sounds like the mechanism for locking the card in has failed, that's a box issue.
