Discussion topic: Viewing card issues
This message was authored by: Alex1267
Viewing card issues
My TV has started saying 'please ensure the correct viewing card is inserted with the chip facing up' we haven't moved anything so not sure why. I've taken the card out, cleaned card and box switched it off and started again still nothing.. can anyone help?
Re: Viewing card issues
hi @Alex1267
Make sure your viewing card is correctly inserted.
When it is correctly Home there should not be enough of the card protruding to remove it without pushing it fully in to release it.
Avatar for Alex1267
Already done. Its as it should be but keeps saying the above.
Hi @Alex1267
