Discussion topic: Viewing Card
This message was authored by: DawsoH
Viewing Card
Message coming up " Please insert your viewing card with chip facing up" Can only access TV channels not Apps or anything else
Re: Viewing Card
@DawsoH try removing you viewing card You can find your viewing card which is located on the right hand side of your box towards the front push the card in until it comes out. Give the chip a clean with a dry lint free cloth then re-insert the card pushing it in until it clicks into place
