Discussion topic: Vewing Card not working
Message posted on 23 Sep 2024 09:37 AM
Despite trying to spak with an actual person i cant reolve my issue as shy q wont opperate as if says viweing card error, I have done the usial fixes but still not working.
Message posted on 23 Sep 2024 10:11 AM
Re: Vewing Card not working
Hi @m.innes
First check that your viewing card is correctly inserted. Viewing card is in the right hand end of the box.
If it is in correctly there is not enough of it sticking out to grip and remove it.
Push it fully in and it will pop out slightly enough so you can remove it.
Take it out and give the chip a gentle wipe with a damp lint free cloth or E-cloth.
Ensure that it completely dry before you reinsert it chip side up and chip end in first. Push it gently fully in and you should feel a slight click when it is engaged. If it has popped out enough to remove it is not located correctly.
If you are satisfied that it is in correctly
Try refreshing your Viewing card.
Home - Settings - System info.
Highlight Viewing card number and then select Setup on the right hand side.
Then select Use this option to trigger a callback
No call is actually made but the Viewing card should be refreshed.
Message posted on 23 Sep 2024 12:37 PM
Hi thanks for your reply.
i have done these fixes again but no joy and as the box cannot see a card as it keeps saying no card inserted in system info settings or "Please ensure the correct viewing card is inserted with the chip facing up" when on Home Screen.
eill need Sky to contact me.
