Discussion topic: Data cache from Sky Q box to Router
This message was authored by: Steve+the+Gooner
Hi All,
I currently have Bt Briadband & router, I want to run a data cable direct rom the router to the main Sky Q box, externally and through the walls approx 15 meters. What data cable is best and will there be an issue with the 15m length please? TIA
Re: Data cache from Sky Q box to Router
Hi @Steve+the+Gooner   Cat5e is good for 100 metres. But I would go for a Cat6 External Ethernet cable to future proof. I have two external Ethernet runs so my house is fully connected. I bought my kits from eBay where you will find plenty or of course Amazon with cable and wall boxes.
This message was authored by: bemak187
@Steve+the+GoonerCAT 5 fine CAT 6 better, very small difference in cost.  Key thing is get external rated cable or the UV will eventually degrade the jacket or there will be water that gets in.
