Discussion topic: Using an AEI HDMI Digisender with the SKYQ Box
Message posted on 11 Nov 2023 09:13 AM
Hi..I am currently running a Sky+HD box with an AEI Digisender unit connected,the Digisender sends signal to a receiver in an upstairs bedroom which is attached by HDMI to a TV I can change channels or turn the Sky+HD box off and on using my Sky+HD remote control in the Bedroom.The system works well as it uses a Magic Infra red eye which connected to the AEI HDMi Transmitter,and the Magic eye sits in front of the Infra red senser on the SKY+HD Box.
Sky are actively encouraging Sky+HD box users to upgrade to the SKYQ box at no extra cost with no instalation fees.I wish to contnue using my AEI HDMI Digisender unit and Magic eye sensor,as I do not want to rent a sky mini box.
Can any one advise me whether I can use my AEI Digisender Digisender with the SKYQ system in the same way as i have been using it with the SKY+HD box? Any advice would be appreciated Michael..PS I am out of contract with Sky at the time of writing and would have to sign up for a new 18 month contract if i wish to upgrade.
Message posted on 11 Nov 2023 09:30 AM
Re: Using an AEI HDMI Digisender with the SKYQ Box
There's no RF on Q - so the magic eye doesn't work.
HDMI extenders for Q are notoriously difficult to get working, especially UHD (as it's 2160p/50). It will depend on the spec of your particular sender as it needs to fully support HDCP and the resolution you plan to run.
Message posted on 11 Nov 2023 11:03 AM
Thank you for your advice,i have heeded it and havecancelled my sky contract to upgrade to skyq.I will stay with my sky+hd box for another 18 months..Michael
Message posted on 11 Nov 2023 11:48 AM
@michaelH0903 Had you already agreed to the Sky Q upgrade?
If so, another possible issue could be on the horizon. There have been reports on here in the past where the process to cancel the existing viewing card still continues. Look out for a new Sky Q viewing card arriving and hang onto it in case your existing viewing card gets canceled.
Sky Community Forum SuperUser
Former Sky+HD Beta Tester
Message posted on 13 Nov 2023 02:01 PM
Hi Thanks for your reply.I have actually cancelled the Upgrade to SkyQ because I discovered that as SkyQ does not have RF,I would not be able to use my Digisender equipment with it?I will coninue with Sky+HD box for the time being Michael
Message posted on 30 Mar 2024 06:45 AM
Hi.
I'm just wondering if you have had anything from sky about them no longer supporting sky+ box issue's.
I use a TV signal sender myself and do not want the Q for the same reason. It appears from an email I received that no more software updates will be provided. I can no longer record BBC 1.
I'm just wondering if a HDMI splitter then convert 1 split to the appropriate connection for the TV signal would work.
Message posted on 30 Mar 2024 08:36 AM
That's something of a red herring from Sky: there haven't been any updates for Sky+ for a considerable time, which isn't surprising given boxes were last manufactured in 2015.
A Sky+ HD box should continue to function for live viewing, recording, playback and on-demand. Some interactive functions may cease.
This hasn't been reported elsewhere, and isn't related to the above.
