Discussion topic: Using Sky Q remote to control LG OLED55C54LA TV
This message was authored by: RBBASS
I recently changed my LG TV to a newer model. I don't seem to be able to use my Sky Q remote to control the new one. There doesn't seem to be the model code in the Sky Q  list.
Do you have any suggestions on how I can enable it to control my TV as it did with the previous model?
Are Sky likely to update their listings of registered models?
This message was authored by: PeteRG41
Re: Using Sky Q remote to control LG OLED55C54LA TV
Just try another code until it works.
Sky Q remotes | Sky Help | Sky.com | Sky Help | Sky.com
"Once you've found your TV make and model, press the volume buttons on your Sky Q remote and see if this changes the volume on your TV. No luck? Select No, try another until you find the right setting."
____
Pete.
Avatar for RBBASS
I'd tried that, but none of the 15 options had any effect.
I can use the Sky remote to start up the TV and Sky box, with it going straight to the Sky HDMI input.
However, I still have to use a combination of the remote controls to switch both TV and box  to off.
