Discussion topic: Useless sky Q box
Message posted on 07 Jul 2023 07:05 PM
Useless sky Q box
Sky q box has no satellite signal also it's not connecting to the WiFi so the box is pretty much useless at the moment any help would be appreciated.
Message posted on 07 Jul 2023 07:10 PM
Re: Useless sky Q box
Hi @Mhewitt
Regarding the No Satellite signal check through the following link
Once you get this sorted to connect the WiFi carry out a Network reset on the Q box.
Highlight Status and then select Reset on the right hand side. Follow instructions to connect by WiFi to your router.
Message posted on 07 Jul 2023 07:54 PM
Thanks for the help the sky q box has now had a forced update and it still won't find a signal reset the WiFi connection and it won't find my router at all things are not good.
Message posted on 07 Jul 2023 07:57 PM
Message posted on 07 Jul 2023 08:10 PM
I'm with sky broadband
