Discussion topic: Upstairs box not responding
This message was authored by: Gary1985
Upstairs box not responding after doing the advised checks
Re: Upstairs box not responding
Hi @Gary1985
Have you tried
First rebooting the main Q box and then when this is completely back up and running reboot the mini.
Reboot the mini as above.
Avatar for Gary1985
The box has a red light and is inactive so you can't even turn it on now
Hi @Gary1985
Have you tried pressing the Standby button (Amber led) on the front of the mini box.
If this turns the mini box on
Try completly resetting your mini Bluetooth remote.
Then make sure that you are pointing your remote at the mini box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair.
