Discussion topic: I received a new mini box as old one was faulty however the sky booster won’t connect
Message posted on 20 Oct 2023 02:00 PM
Message posted on 21 Oct 2023 09:50 AM
Re: I received a new mini box as old one was faulty however the sky booster won’t connect
Hi @WT2
Your post has been escalated to our Community Messaging team who will invite you to a private chat shortly and help you with this.
Just look out for the chat bubble to start the conversation.
Here's more information on how Community Messaging works - https://community.sky.com/t5/Did-you-know/Escalating-a-post-to-a-Sky-expert/ba-p/3711147
Tom
Message posted on 23 Oct 2023 09:50 AM
We are still looking to help you WT2. If you need our support let us know and we can re-escalate to our chat team. Your invite has been closed now. Thanks
Message posted on 23 Oct 2023 10:10 AM
Hi @WT2
Assume it's a Q WiFi booster located between the mini and the main Q box.
First you need to check the booster is connected to the main Q box.
Go to your main Sky Q box and press and hold the WPS button (far right) until its amber light starts to flash. Go to your Booster and press and hold its WPS button (far right) until its amber light starts to flash. The Booster will connect and its Connect light will turn solid green when the connection is stable.
Then carry out a Network reset on he mini.
