Discussion topic: Uphrades
This message was authored by: Mick3
Message posted on 04 Sep 2023 06:22 PM
Uphrades
I upgraded to hd last week but still can't access the hd channels. Receiving message 'card not paired' but when I go to settings I see that the card is paired. Is it normal to have to wait for the hd to be switched on?
Find out more
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Message posted on 04 Sep 2023 08:18 PM
Re: Uphrades
@Mick3 You could try refreshing your viewing card by pressing home > settings > system info > viewing card number > setup > viewing card setup press select to trigger a callback don't worry nothing to do with your phone its only Sky's terminology this will be done over the internet
