Discussion topic: Upgrade
This message was authored by: Sazzle65
Upgrade
I wanted to know how much it would cost to upgrade so that I get Sky Atlantic & other channels but NOT sports or cinema
Re: Upgrade
For Atlantic you need the base 'signature' pack.  It's around £30pm but can vary on your deal/discounts.
Re: Upgrade
Do you already have SKY Q (or SKY HD) ?
What 'base' package do you have - as only Essentials (which is  just the FTA channels)  is the only package that doesn't include SKY Atlantic.
If you don;t have Essentials , are you trying to download  something from Atlantic & getting an upgrade message ?
If so try changing your download preference to SD
Main Menu -> Settings -> Setup -> Preferences
